Use this procedure to configure Forward Error Correction (FEC) on supported ports.
Configure Clause 108 FEC on a 25 Gbps port 1/1:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitethernet 1/1 Switch:1(config-if)#fec cl108
Verify the configuration when a 25 Gbps optic is present:
Switch:1(config-if)#show interfaces gigabitEthernet config 1/1
Port Config
PORT DIFF-SERV QOS MLT VENDOR
NUM TYPE EN TYPE LVL ID NAME
1/1 25GbCX true core 1 0 Extreme
Port Config
PORT ADMIN OPERATE AUTO ACCESS-SERV RMON FLEX-UNI ADMIN APPLICABLE OPERATE
NUM ROUTING ROUTING RECOVER EN FEC FEC FEC
1/1 Enable Disable Disable false Disable Disable Auto CL108 CL108
Verify the configuration when a 10 Gb optic is present in a 25 Gb port:
Port Config
1/1 10GbSR true core 1 0 Extreme
1/1 Enable Disable Disable false Disable Disable Auto Not Applicable Off
The following table defines parameters for the fec command.
Variable |
Value |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
{auto | cl108 | cl74 | cl91} |
Configures one of the following options for FEC on the port:
Note:
On a 100 GbE port, only the Clause 91 and Clause 108 options are supported. On 100 GbE channelized ports (operating at 25 Gbps speed), you can configure Clause 108 for extra latency or Clause 74 for reduced latency. Configuration of FEC is not supported on a management port or on 100 GbE ports operating at 40 Gbps speed. Important:
On ports that support FEC, always configure the same option on both end-points. Otherwise, the link does not come up. |
